I'm looking for something with a motor and pump to build my water cooling set up for my tig. Something similar to what would come on the carbonator set-ups. If you have anything similar to this, PM me with your price shipped to Kissimmee Floridaq 34743.Thanks!Lincoln Square Wave 175 TIGLincoln 110v flux core welder (my 1st)Clarke 180EN MIG
Reply:Find a soda fountain service guy in your area. We have one in western Ma. He has a pile of them, and gave me 2 complete units plus fittings. If you can't find one, go to a small non-chain restaurant that has fountain soda and ask who services the equipment. Good luck. Steve
Reply:Another option is Fee Bay. Prolly not the cheapest, but available shipped directly to you. Just a thoughtBobI'm spending my Kids inheritance, I dont like him that much anyway!!!!!!Enuff tools to do the job, enough sense to use em.Anybody got a spare set of kidneys? Trade?
Reply:check out little giant pumps submerible 110/120v have used one for yrsidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:thanks for the tips...I have been looking on eBay and every time I think I have found a good deal. The big goes way to high in the last few minutes. Finding a local resturant equipment place is my next step... I found a few nice little giant submersible pumps, but which to get? Not sure on the GPH i would need???Lincoln Square Wave 175 TIGLincoln 110v flux core welder (my 1st)Clarke 180EN MIG
Reply:mine is a : E2 series, E2-38Ni think the new number is: 500203-1-A mine moves 380+ gph and lifts 11.8 ft have to look in the morningi picked one that gave the most lift so ican weld atop boats and pontoonsLast edited by prop-doctor; 11-23-2010 at 01:25 AM.idealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:found this place when i was looking at pumps, they offer remanufactured and new procon pumps.. http://www.edcodistributing.com/pcpumps.php also looked at the pumps propdoc recommended, i didnt really want to spend that much yet.. i ended up going to harbor freight and getting a 268gph fountain pump. it has like 7ft max lift, cost $20. havent got the cooler put together yet so i couldnt tell you if it will work good enough or not... i do know if it doesnt i'll get the pump propdoc recommended and stick the harbor freight pump in my bird bath..tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:You will need a pump that can maintain 50 psi and flow 2+ gallons per minute through 1/4" id tubing if you want to make a good cooler. Don't settle for less, as you will be gambling your torch and leads on it. If that pump can do this it will be then it will be fine. If not, you will likely need to buy a new torch as well as a bigger pump. I made my cooler using a procon pump from a carbonator, the 2 gal tank from the carbonator, a transmission oil cooler radiator, and two muffin fans, and assorted pipe fittings. My total investment was about $150 and took about 6 hours to build. It has been in use for almost 2 years now with no problems at all.CharleyLMiller MM252Miller Bobcat 225NTMiller DialArc HF / DIY Cooler2 Victor O/A TorchsetsMilwaukee 8" Metal SawMilwaukee Dry Cut "Chop" Saw 5 Ton Wallace Gantry Various Grinders, Benders, etc. |
