Tips on fluxcore
发表于 2021-8-31 22:29:20 | 显示全部楼层 |阅读模式
Any advice on fc vertical up on 3/16 angle welded to 1/4 bar I'm using fabricator 252i with .045 lincoln nr 211 mp with no gas
Reply:Also how is l 56 wire
Reply:I run  a lot of NR-211 but in the .035 size if I were you i would run stringers just hold the gun at a 90 degree angle to the weld joint and run straight up at a steady pace and watch the sides to make sure it fills in well.Lincoln pro core 125 14''chop saw7 inch grinder,2-4.5 inch grinders,electric die grinder.Half inch drillAnd alot of hand tools
Reply:Originally Posted by FlyingJAlso how is l 56 wire
Reply:Build a shelf first, then turn the gun slightly down, little side to side motion, and travel up. Make sure the puddle lays on the shelf all the way up. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:How do I open images
GMT+8, 2025-12-31 20:05 , Processed in 0.120523 second(s), 18 queries .
