need help with miller 350p
发表于 2021-8-31 22:29:17 | 显示全部楼层 |阅读模式
My neighbor bought a used miller 350p. He is frustrated with this machine because when he turns it on the led screen powers up and you can hear the machine humming. It doesn't matter if he starts welding or just lets it sit there, soon it will turn the led screen off but the machine is still making noise like it is ready for welding. The screen will be off just like someone flipped the switch to power if off. I would appreciate any advise if someone has been through this before..
Reply:My first guess would be that he has the machine wired improperly.Check the input voltages.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:Even though sometimes it welds for say like 5 min the just turns the led screen off and machine is still running? And when you pull the trigger nothing happens?Thanks for the thoughts and input.
GMT+8, 2025-12-31 18:44 , Processed in 0.098153 second(s), 18 queries .
