part finding help
发表于 2021-8-31 22:29:11 | 显示全部楼层 |阅读模式
anyone know of a source for steel threaded t handles ive been searching for awhile but all i can find is plastic t knobs most are just plastic molded over a bolt that end up slipping thanks for any help350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:Couldn't you just weld a bar across the top of some threaded rod?Miller Syncrowave 350Millermatic 252/ 30A spoolgunMiller Bobcat 225g w/ 3545 spoolgunLincoln PowerArc4000Lincoln 175 Mig  Lincoln 135 Mig Everlast 250EX TigCentury ac/dc 230 amp stickVictor O/AHypertherm 1000 plasma
Reply:yes ive done it a bunch but its for something im making and im trying to find out if i can find them premade somewhere cheaper then i can make them350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:Googled 'steel t handles' and found ths...  http://www.mjvail.com/KwikLok/Thandle.htmlRick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:Page 8-4 http://www.elkhartbrass.com/files/aa...g-f2-08-03.pdfStandard is for 1/2" rod but available threaded.  ??MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Have you looked at Carr-Lane?  http://www.carrlane.com/catalog/inde...1A3C3B28535647
Reply:thanks guys ill check into those 350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:These guys do handles. I've never ordered any from them but they look good. They're the only place I've managed to find metric bearing retaining nuts which is what I've ordered in the past. They're a little slow on the delivery but good quality on the nuts.http://www.jwwinco.com/Millermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
GMT+8, 2025-12-31 18:44 , Processed in 0.096158 second(s), 18 queries .
