Anyone know anything about this Tig machine?
发表于 2021-8-31 22:29:10 | 显示全部楼层 |阅读模式
http://cgi.ebay.com/ESAB-Heliarc-252...#ht_1649wt_886Is it any good? What are they worth? I cant find any dealers on the web.
Reply:its only a power source for a little $$ more buy a lincoln or miller complete welding set up..Of all the things I lost I miss my mind the most...I know just enough about everything to be dangerous......You cant cure stupid..only kill it...
Reply:I paid about the same for my Lincoln Tig, which did include a torch, pedal, etc. (but no stick electrode holder) but after reading the specs it seems like the Esab is a better, or at least more versatile, machine.The only thing it looked like the Lincoln has that the Esab does not is pulse.  In the picture it shows it on the board but the knob is blanked out, so I guess that is on a more expensive machine.  I haven't even used the pulse on my machine yet, it is freq. adjustable only.  You cannot change the background current, % on time, etc.
Reply:http://www.bakersgas.com/ESA36205.htmlthey don't make them anymore thoughEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:ESAB make great machines.  That's probably much more machine than you would needunless u r in a shop setting an using it all the time.    How about something like the 225 square wave Lincoln.   If u go mch over that amperage u will be needin.g a water cooled torch setup too.  It also neds a 100amp power supplyLast edited by soutthpaw; 07-01-2011 at 03:47 PM.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Soutthpaw,You can NEVER have too much machine. ANd a machine that needs a 100amp power supply can be dialed down so as not to exceed a 50amp circuit. I just wanted to say that. because you can have too LITTLE machine. Just my thoughts.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Thanks guys.
Reply:Justin,That is a great tig welder.  It's on a par with the Miller Syncrowave 250 or the Lincoln 275.ESAB actually bought the old L-Tec who owned the patent rights to the original Heliarc machines. (Heliarc to Linde, Linde to L-Tec, L-Tec to ESAB)If you could get the machine for that price, it would be a steal, but I think it will go much higher.Do a google search of ESAB and you'll better understand what the company's about.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:i have one with the arc force on max it will go to 420 amps according to the manual.the digital amp meter ,the pulse and current control module can be bought and added later .i they are about 200$ a piece.a 100 amp breaker will run it.it will break a 60 amp upon start up every now and then.millermatic 35      acdc thunderboltesab 2522 oxweld w-17 torchesesab plasma cutterspeedway fluxcoreold bug gas welderROLL TIDE
GMT+8, 2025-12-31 18:45 , Processed in 0.098249 second(s), 18 queries .
