Just curious as to a ball park on how much a rebuild would cost on one of these machines (Engine only) any help or advice would be apprecitated thanks
Reply:go to www.billswelderrepair.com ..... i have not delt with them personally but i have only heard good things. where are you located? that might help other members try to fing someone locally for you.63' Lincoln SA200 2008 miller trailblazer 302fibre-metal pipelinermiller camo BWEand all the guns and ammo a growin boy needs
Reply:Parts only, or parts and labor?If you just do rings and bearings you can probably get the parts for a little over $200.If you are talking boring cylinders and new pistons you are up around $500.Bad cam, timing gears, etc add more $Joewww.CummingsHauling.com
Reply:South ms. I already have a 77 model sa 200 and absolutely love it so smooth! i am possibly gonna buy another one locally. How much of a job is it to replace rings and bearings
Reply:Not a big deal. If I had all the parts laying there I would guess about 4 hours. That is just figuring doing rings and bearings in an otherwise good running f163.Joewww.CummingsHauling.com
Reply:Thanks for the input guys i did get the machine today very pleased with it but has a little blow by i hope the new rings will fix it. Any pointers on anything else to look for? |
