1935 Camera Robot
发表于 2021-8-31 22:28:58 | 显示全部楼层 |阅读模式
This has been sitting on my workbench waiting to be finished for a while. Finally got around to finishing it up. The lower parts of the legs are adjustable, and the camera will raise up a couple of inches and swivel 360 degrees. String of Battery powered LEDs around the bottom in case it is dark and it can't see very well. Wire wheel finish and clear coated.For the amount of welding, it took way way too long to get done.  The camera is a Moviematic Motion Picture camera from the 1930s.
Reply:Amazing work on that piece. Did you cut the legs or are they re-purposed from something?Sent from my SPH-L710 using TapatalkTOO MANY TOOLS & NO MORE SPACE
Reply:You need to get that bad boy down to south Florida for a flight to Mars.
Reply:Originally Posted by Chris T.Amazing work on that piece. Did you cut the legs or are they re-purposed from something?Sent from my SPH-L710 using Tapatalk
Reply:Awesome job on the legs.The lighting is perfect.TOO MANY TOOLS & NO MORE SPACE
Reply:That's very cool! Well done on the legs.
GMT+8, 2025-12-31 18:24 , Processed in 0.105913 second(s), 18 queries .
