light bar for my tractor
发表于 2021-8-31 22:28:56 | 显示全部楼层 |阅读模式
Ok first time and from my phone so here goes nothinok they are out of order. We normally feed our cattle at in the dark since its dark at 5 here in nd. We keep our cattle on our home quarter and I know this quarter like the back of my hand but I shi* u not I got lost hahaha. So this was the fix  The pic of the the bar on the roof of the tractor should have been first. I needed the final measurement for the back of it. The other 2 are obviously finished product. Wired the lights through the tube was fairly ez till the last couple lights went in. I just used welding wire.  Got the lights from amazon. Led. Pretty cheap. Also you don't need anything to juice them other then your battery. I built it last fall and have not had any problems with it. They do the job but don't throw out there like halogens.  When your around objects like trees or bale stack they light it up like the day. Overall I'm happy with them.  The bar fits great and is solid so the lights don't bounce around driving over the frozen turds. Pretty excited to c how they do cutting and baleing.p's i built the fuel tank too. pss i built it in the middle of moving out of my shop if your wondering about the mess Attached Images
Reply:Looks like you have plenty of light now.Does the whole frame move side to side on those telescoping tubes, or did you weld them in place when you had the distance set?
Reply:That should do the trick .  Thanks for posting
Reply:Originally Posted by FernTJLooks like you have plenty of light now.Does the whole frame move side to side on those telescoping tubes, or did you weld them in place when you had the distance set?
Reply:Originally Posted by d3aNpss i built it in the middle of moving out of my shop if your wondering about the mess
Reply:Nice job, Your neighbors will think something  is landing in your field with all them lights.Would love to see a pic of it at night.TOO MANY TOOLS & NO MORE SPACE
Reply:I bought a rocker switch for it but my buddy insisted I put the top gun switch in it haha. Attached Images
Reply:Gotta have a cool switch!Are the back of those lights a big heat sink? Can you give me some more info on them? I'm looking for some like that.GravelThe difference between theory and practice is that in theory there is no difference.
Reply:http://www.amazon.com/gp/aw/d/B009ES...=SY115&simLd=1http://www.amazon.com/gp/aw/d/B00AR7...=SY115&simLd=1top link was the wire harness i used.Bottom link was the lights i used.The harness had 2 spots to plug in. I hooked 4 lights to each of them. There is a small relay in the wire harness. But like i said it works perfect.  I have had no issues with power. Led uses very little.Last edited by d3aN; 06-11-2014 at 01:32 PM.
Reply:Good stuff! I'm going to order some to make my own work light.GravelThe difference between theory and practice is that in theory there is no difference.
Reply:Nice job.I take it not many low hanging trees around to be concerned about adding guards over the lights to keep from cleaning them off?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Originally Posted by duaneb55Nice job.I take it not many low hanging trees around to be concerned about adding guards over the lights to keep from cleaning them off?
GMT+8, 2025-12-31 18:24 , Processed in 0.100799 second(s), 18 queries .
