joining the soda can band wagon
发表于 2021-8-31 22:28:55 | 显示全部楼层 |阅读模式
So I'm seeing these posts on soda (or pop for you hosers) can welding, and in my 15 years or so of tig welding, I've never tried it! well after reading zaps post about twenty min ago, I dug a pair of cans out of the recycling bin and went to work.Dialarc HFaclow level50 on the amperage dialstraight argon 15cfhW17 torch1/16 tungsten (2% sharpened not balled)#5 cup1/16 4043 filler (smallest I have)I layed the cans in a angle iron cradle and went to work. I really like my dialarc, its old school, but its reliable as all hell and does what I need it to do, though I will likely replace it this year with a more efficient and space saving unit (HTP221dv or dynasty 280dx)  What cameras are you guys using? its probably time I join the 21st century, I think I've had this one since the early 2000's and I can't get a good photo no matter what setting I use. Attached Images'14 HTP invertig 221Thermal Arc 201ts'15 HTP 2400'13 Hypertherm Powermax 30Esab 875Esab 251Clark Metal Servicespecializing in stainless steel exhaust systems
Reply:I think tomorrow I will do this on the syncrowave 250dx @ work and see if I feel it was any easier or had any better results.'14 HTP invertig 221Thermal Arc 201ts'15 HTP 2400'13 Hypertherm Powermax 30Esab 875Esab 251Clark Metal Servicespecializing in stainless steel exhaust systems
Reply:looks good.  Try taking the picture with the flash off and it will probalby be better.
Reply:Looks good - that was better than my first try at it   I'm gonna have to try it again now Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Wow guys.  Have your tried the wrappers on chewing gum??? Amazing
Reply:Originally Posted by Brent878looks good.  Try taking the picture with the flash off and it will probalby be better.
Reply:Woulda been more impressed if you used a beer can!Arcon Workhorse 300MSPowcon 400SMTPowcon SM400 x 2Powcon SM3001968 SA200 Redface1978 SA250 DieselMiller Super 32P FeederPre 1927 American 14" High Duty LatheK&T Milwaukee 2H Horizontal MillBryan
Reply:Originally Posted by blawlessWoulda been more impressed if you used a beer can!
Reply:Jack and Coke it is! Originally Posted by MinnesotaDaveHow you gonna get the proper shake in your hand that way? Beer takes away the shakes, caffeine puts it back...Whiskey and coke they have to fight it out
Reply:sailor pepsi, and zero carb rockstar and vodka, that is where I get all of my inspiration. beer is for bbq, booze is for imagination.I welded a pair of monster cans today @ work with the syncrowave 250dx, and to be honest, it was no easier or better than @ home with my dialarc HF. I had it just to the ac side of weld balance, about 25amps 1/16 2% thoriated wp9 and .040 4043. One thing, the syncrowave seemed to struggle a bit on the lower end of amperage, and it even shut itself off. This is why I am leary of newer miller products. our shop has owned our two dialarc HF's for nearly 30 years (since new) with ZERO EVER problems. they've NEVER broken or malfunctioned, and are used all day every day.'14 HTP invertig 221Thermal Arc 201ts'15 HTP 2400'13 Hypertherm Powermax 30Esab 875Esab 251Clark Metal Servicespecializing in stainless steel exhaust systems
GMT+8, 2025-12-31 18:43 , Processed in 0.097420 second(s), 18 queries .
