Metric Step Stud help please
发表于 2021-8-31 22:28:51 | 显示全部楼层 |阅读模式
I need to find 6 metric step studs, but so far have come up empty for exactly what I need.I need 6 studs that are M12 on one end and M20 on the other.The M12 end can be ~1" (25mm) long, and the M20 end should be ~2" (50mm) long.These need to be fairly strong grade.  Finish is not important, but black oxide is preferred.Something like this:Any help would be greatly appreciated, thanks!
Reply:Try searching around on  www.McMaster.com
Reply:I tried McMaster, they don't carry them.
Reply:Can you find someone with a lathe who can turn down some M20 studs to the M12 that you need? That may be quicker
Reply:Hadn't thought if that,  but I don't think any of my friends have a lathe. Checking with Fastenall and a couple of other suppliers. Sent from my SPH-L710 using Tapatalk
Reply:Originally Posted by LuMaxThese need to be fairly strong grade.
Reply:Originally Posted by LuMaxHadn't thought if that,  but I don't think any of my friends have a lathe. Checking with Fastenall and a couple of other suppliers. Sent from my SPH-L710 using Tapatalk
Reply:Edit your profile to include location, I bet someone on these forums with a lathe could help you out
Reply:Thanks for the help guys.  I was out of the country for 5 days so haven't responded.I managed to come up with an alternative solution since these weren't readily available.I've added my location to my profile, and will remember to use a commercial machinist when I need too.Just very used to utilizing the "buddy network".
GMT+8, 2025-12-31 18:45 , Processed in 0.107095 second(s), 18 queries .
