Bend tester
发表于 2021-8-31 22:28:48 | 显示全部楼层 |阅读模式
What kind of material do you all recommend for the shoulders of a bend tester ?  Would 4130 tool steel work ?  What if I heat treated it ?  I have a tester made up now, but just tossed it together with mild steel shoulders (rollers that don't roll).   Just as I figured they don't seem like they will hold up long.Journeyman / Red Seal Welder (What a useless test)Miller CST 280Miller XMT 350Miller 12vs XtremeEvolution Evo 28 mag drillEvolution 380 Dry Cut saw
Reply:I used the two 1 1/2“ diameter rolls out of my Harbor Freight compact bender. Welded a piece of 1 1/2“ round stock perpendicular to a piece of 1 1/2“ shaft. To insert into my small shop press. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:How about big diesel wrist pins. That's what I use and they work good, mine don't spin either and I used 1.5 inch wrist pin. The shoulder can be any size but needs to be hardened and the plunger must be 1.5" and the shoulders 2 3/8 apart I believe.
Reply:AWS D1.1 Guided Bend Test Jig."Discovery is to see what everybody else has seen, and to think what nobody else has thought" - Albert Szent-Gyorgyi
Reply:I have the design guys its in the Procedure handbook by Lincoln.  Just need an idea of material to use.Journeyman / Red Seal Welder (What a useless test)Miller CST 280Miller XMT 350Miller 12vs XtremeEvolution Evo 28 mag drillEvolution 380 Dry Cut saw
Reply:heres the big diesel wrist pins in use bending 3/8 AL. My bender is setup for .5" too. My plunger is also a wrist pin right at 1.5". You could maybe use a big hardend bolt also
Reply:Im more along the lines of thinking what material I can just go and buy.  Would tool steel work and what grade ?Journeyman / Red Seal Welder (What a useless test)Miller CST 280Miller XMT 350Miller 12vs XtremeEvolution Evo 28 mag drillEvolution 380 Dry Cut saw
Reply:i used 4140 prehardened when i build them for my last two shops prehardenedAWS CWI xxxx21711968 SA200  Originally Posted by WelderMike  I hate being bipolar, It's awesome.
GMT+8, 2025-12-31 18:24 , Processed in 0.107087 second(s), 18 queries .
