Enginious1
发表于 2021-8-31 22:28:44 | 显示全部楼层 |阅读模式
Have my eyes on a new xmt304 cv/cc machine with a xr a wire feeder.   I am wanting to know if i can use a regular mig gun on this feeder to run 035 or 045 wire  instead of push pull aluminum pistol whip that this feeder seems to be designed for. I am not familiar with stuff this new and i dont think my olde miller suit case will interface with this power supply. Anyone have any input??
Reply:Assuming you will be doing Aluminum then?  I think you can run steel wire through a push pull as wellTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Well aluminum is not what i work with most of the time, thats why i am questioning the possibillities. Of using a std whip about 200 amp withy just a push from the unit.
Reply:No, a standard gun will not work on that XR cabinet, but the XMT will run just about any 115 or 24 volt wire feeder miller ever manufactured with the correct connection cord on it.What type of feeder do you already own?Expert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:[QUOTE=7A749;6273421]No, a standard gun will not work on that XR cabinet, but the XMT will run just about any 115 or 24 volt wire feeder miller ever manufactured with the correct connection cord on it.What type of feeder do you already own?[/QUOTEMILLERMATIC SUITCASE  MHFC-MW-1    IT IS OLD BUT HAS ALWAYS WORKED GOOD.  MAYBE AN ADAPTOR TO RUN CONTACTORNAND GAS VALVE WILL BE AVAILABLE??????   jim
GMT+8, 2025-12-31 20:31 , Processed in 0.101881 second(s), 18 queries .
