Trailer Mounted Miller Welder
发表于 2021-8-31 22:28:35 | 显示全部楼层 |阅读模式
I am selling welder, trailer, large box, bottle rack, and vice.  The welder is a 86 Miller trailblazer it is 250AMP DC stick capable of hooking wire feeder up to it, it also has 3 kw of back up power. Welds nice and all power outlets work.  Welder has a 2 cylinder onan engine and 698 hours on the machine.  Large box on front of trailer is a 24"x24"x48" with lockable lid.  Bottle rack is capable of holding 4 gas cylinders, vise is a 6" Kobalt.  The trailer is a 5'x8' with 14" wheels and tires with 500 miles on tires.  Axle is 2500LBS with a 2" ball coupler.  The tools, small black box, and leads are not for sale just large box, trailer, welder, bottle rack, and vise. May seperate.  Trailer is a good puller with no sway at highway speeds and also long enough to make it easy to back. $1700  Josh 336-577-3266 Attached ImagesLast edited by Josh Flynn; 12-02-2010 at 09:44 AM.Reason: forgot price
Reply:Hey Josh where do you live? I stay in Rockingham don't know if you know where that is or not. I may be able to help you sell it. To be an older welder it looks to be in good shape. Nice looking setup to.Miller Bobcat 250Westinghouse ac arc welderIts better to be hated for who you are than liked for who your not.
Reply:I know about were Rockingham is, I am located in Winston-Salem.  If you know any one looking for a good welder, this one sure is.
Reply:I'm just curious because I have never seen a machine like that but how does the amp settings work?Is that big knob for ranges and how do you set the fine adjustment?I once saw a welder for sale that had about 8 female sockets to plug your welding cable into and that was how you could control heat output. I laughed at the time but I would love to see what I could do with it in a pinch.Last edited by feetfats; 12-15-2010 at 03:46 AM.
Reply:You have a large course adjustment knob, with three settings for CC and two settings for CV mode. Located beside the course adjuster is the fine tune knob with a 0 to 100 scale.
Reply:I have removed the welder from the trailer, so for anyone interested in just the welder let me know.
GMT+8, 2025-12-31 18:43 , Processed in 0.098750 second(s), 18 queries .
