pump needed
发表于 2021-8-31 22:28:35 | 显示全部楼层 |阅读模式
I am looking for a pump to use on a TIG cooling installation.  I have a tank and all the fittings, I just need a small pump.  Does anyone have a source for something that will work?  Thank you.
Reply:I don't have numbers for how much heat you need to take out of the torch for a given amperage.  Using numbers I have for heat exchanger water velocities, here's what I come up with:Hose size: 3/8"Water velocity: 5 fpsFlow Rate: 1.7 gpmI looked at submersible pumps, and they are rated for gph, so you would need something around 100 gph.  I would look to a pet supply store and get a fish tank pump.  Harbor Freight also sells something that is rated in that range.I hope this helps,Fegenbush
Reply:i use little giant submersible  pump (going on 19 yrs total) check out there site they have some that are submers/ inline and straight submersmine is 300 gph with 12 ft lift. been good for me have used the first one for 15 yrs it was used bought new one 4 yrs ago  cost around 45 bux ,you need flow  not pressureidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:Most of the welding coolers use a ProCon soda fountain pump with 110v electric motor that also turns the fan.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:You can search on amazon,eBay, or any horticulture supply web site for a Mag Drive pump or off brand of mag drive. This site's a little expensive but here's a 250gph Mag Drive for $66. I've used the same one in my drip garden for the past 5 years running basically continuous when I actually have a crop in it. They are 120V, completely sealed, no oil inside, magnetic drive. A torch cooler isn't as critical in terms of contaminants as a garden, but you'll never have to worry about the pump leaking or running hot. And they make them in all different capacities, from around 50gph to a few thousand gph.
Reply:Thanks guys.  That gives me some ideas of where to look.
GMT+8, 2025-12-31 18:44 , Processed in 0.124951 second(s), 18 queries .
