SA200 350bucks Clist Atlanta not mine!
发表于 2021-8-31 22:28:34 | 显示全部楼层 |阅读模式
Lincoln SA200 arc welder - $350 (canton)http://atlanta.craigslist.org/nat/bar/2122939602.html"Mid 70's lincoln sa 200 arc welder. 4cyl. gas engine runs good. 115 volt generator works. The welder will make a little spark but I cant get it to weld. And I know nothing about them. Also comes with leads. "
Reply:Keep postin' up stuff like this farmall and I'm gonna send your 'puter a bug!  Almost can't even buy a broken down parts unit around here for that!MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Farmall , looks like you may be costing me sum money ! I can't help but to see if the guy still has this thing.
Reply:Happy to help!Keep postin' up stuff like this farmall and I'm gonna send your 'puter a bug!
GMT+8, 2025-12-31 18:45 , Processed in 0.092387 second(s), 18 queries .
