Another Soda Can
发表于 2021-8-31 22:28:34 | 显示全部楼层 |阅读模式
I did this can with 4943 and it welded very nice, much better than the 4043 I had been using since the first can....I did weld one with 5356 which Terry recommended and it welded nice also.....http://img.photobucket.com/albums/v9...psyaesrlfq.jpgLast edited by B_C; 04-23-2014 at 11:17 PM.  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Still amazed on how you make a can weld look so good. I can't get a ripple/bead appearance on them.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Nice!!!
Reply:Turn the heat down to 50 or so and use a 040 red tungsten sharpened to a point....1/16 filler and keep the filler under the heat of the tungsten and keep moving.....Tack in two spots 180 apart  wash the cans out and dry on your stove.....clean the weld areas with scotch brite wipe down with acetone.....punch a hole in the bottom of one can first.......  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:BC,Impressive work.
Reply:I'll practice first on a few alum truck rims. Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:never had much luck repairing Aluminum Rims......Unless you have a way to bring back the Hardness your kinda wasting your time since they get annealed when you  weld on them.....Just my opinion   Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Looks great BC, thanx for the tips.
Reply:Im having a terrible time getting the size of my pics correct...Sorry about the  Huge size....  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:That looks pretty good Bill.Your advertizing idea is a really good one.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Looks great! You weld reel purdy for an old phart.Two turn tables and a microphone.
Reply:[QUOTE=B_C;4090731]I did this can with 4943 and it welded very nice, much better than the 4043 I had been using since the first can....BC, where do you recommend sourcing the 4943?  Nobody where I live carries it...
Reply:Check with Miller, they own MAXAL who makes it in Mich.  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Originally Posted by PangeaLooks great! You weld reel purdy for an old phart.
GMT+8, 2025-12-31 18:24 , Processed in 0.151081 second(s), 18 queries .
