Decisions on TB302
发表于 2021-8-31 22:28:30 | 显示全部楼层 |阅读模式
I have the opportunity to purchase one of two Trailblazer 302's.  One is a 2005 with 325 hours, gas engine, 100' of #1 welding cable, through an individual on Craigslist for $3,000...  The other is a CeeKay rental, a 2009 with 519 hours, running gear, LP engine, one year Warranty for $3,200.  Tell me which one you would recommend.
Reply:I wpold buy the one with the gas engine just because I am not used to lp in a application like this. Both seem have low hours. The warranty would be a plus on the one but what youd pay for the cable on the other that would go aways towards a repair bill also unless they both have leads. I would look at both check condition and weld test both.Millermatic 252millermatic 175miller 300 Thunderboltlincoln ranger 250smith torcheslots of bfh'sIf it dont fit get a bigger hammer
Reply:Keep in mind that with a LP machine, you could bring it inside a building and run it (anywhere you could run a LP forklift) whereas the gas engine is going to have to stay outside and away from the doors (exhaust fumes).  This might mean you'd need a lot less lead with the LP machine than the gas engine."The reason we are here is that we are not all there"SA 200Idealarc TM 300 300MM 200MM 25130a SpoolgunPrecision Tig 375Invertec V350 ProSC-32 CS 12 Wire FeederOxweld/Purox O/AArcAirHypertherm Powermax 85LN25
Reply:I would buy the gas machine personally having been out on a job in the middle of no where trying to find diesel fuel i can imagine it would have been much harder to find lp. That beening said if that doesn't bother you or you have a tight grid you work then the lp machines burn much cleaner and have better longievity over the reg gas machine.Vantage 300 kubota ,miller 304 xmt ,lincoln ln 25 pro , ranger 305 G, plenty of other tools of the trade to make the sparks fly.
Reply:If you will use it often, then the gas would be acceptable. If you are going to use it "ocasionally", then I would go for the LP.Gas goes bad fast. LP does not go bad."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:LP is out for field work.  I've got a buddy that had two of them and dumped them both quick.  Nothing worse than being at a remote job site and running out of fuel.  And according to him even in the best conditions it was a pita getting the tanks refilled.  Propane is expensive and the prices goes up faster than gas does.... he had to get filled at RV places... slow process as you can't do it yourself and said he was always hunting someone to come fill it...Fine for forklifts as you can keep a spare tank sitting around.
GMT+8, 2025-12-31 22:22 , Processed in 0.096826 second(s), 18 queries .
