cut off wheels anyone try theses
发表于 2021-8-31 22:28:28 | 显示全部楼层 |阅读模式
need to get some cutoff wheels  been using HF thought about trying the metabo same price as HF then i ran across these on ebay 100 wheels for 30 shipped anyone try em before  ? http://cgi.ebay.com/100-NEW-1-32-Inc...item4cf6b0bb1a350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:i dont use a die grinder for cutting. i use a 4 1/2" grinder with Sait cutoff wheels.bout all i do with a die grinder is prep/deburr with twist-loc sanding pads.tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:thats all well and good i use them on a grinder aswell but 3 inch on an angle grinder fit lots of places the other wont 350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:The ad doesn't give many details, like the construction (if reinforced w/ fiberglass), the grit size or the rated maximum speed. I use discs similar to those for lots of things, e.g. for cutting off rivet heads or slotting screw heads; a die grinder gives more control for small work than an angle grinder would but each has its place.
Reply:I'd say they're cheap enough, but I wouldn't expect much.
Reply:I use cut off wheels a lot and I can tell you that I buy wheels that are sound. I have scars of 5 stitches 6" down from my left palm where a cut off wheel got thrown from me and went into my arm. 30 cents a piece sounds like a great price, but if they got damp, or are old, and are falling apart, you might loose really bad in the deal after the purchase.
Reply:use the metabo cut off wheels.  they are way better than HF
Reply:I don't know about the ones on flea bay but any of the abrasives from HF are crap.  I took a chance on some of their 14" chop saw blades once and it made exactly 22 cuts through 1 1/4" 16ga square tube before the blade was worn out....  Their sand paper is equally as bad.We used to use a large number of the twist lock dicks (Norton) until the prices got crazy a few years back.  At close to a buck each even in bulk it's just money down the tube.  We went back to the angle grinders and flap wheels  Flap wheel lasts 10-20 times as long as a twist lock and I can buy them for 3 bucks each.I don't buy any consumables with the "metabo" name on it.  Prices are ridiculous and they don't last any longer.Buy the ones off ebay and give us a report!
Reply:I don't use air die grinders at home. I use 5" Norton wheels from home depot for my 4 1/2" grinder. The extra circumference cuts much faster. The less expensive wheels cut slower and turn to dust much faster, so they're actually MORE expensive and much more dangerous (how much does a trip to the ER cost?).Welding/Fab Pics: www.UtahWeld.com
Reply:I haven't used the 3/16 or 1/16 small cut offs from them, but I had to go to an industrial plumbing supply place here a couple of weeks ago to get some real heavy PVC for our air system and they had just started carrying metabo grinders, abrasives and grinding wheels.  I bought two flap wheels and a grinding disk just to try them but they werent cheap.  I think the flap wheels were 7 bucks but they are about the best I have used even better than the norton ones I think.  They have the built in mandrel so no need to mess around with the collets.  Nice quality for sure.  The grinding disks seem about the same as norton or dewalt...
Reply:By MikeGyver;I use 5" Norton wheels from home depot for my 4 1/2" grinder.
GMT+8, 2025-12-31 20:30 , Processed in 0.098882 second(s), 18 queries .
