I know it's discontinued but does anyone know where to find one in stock or another gun could be used in its place?
Reply:Well, what we do generally is use the Miller 30A spoolgun with a WC-24 Controller, and mate it into a Weld Alert universal hub. That way you you can run that top quality spoolgun on any welding power source you want to adapt to.
Reply:If you still want to do this, my customer thinks he has the adapter that fits into front panel of the W/M 255 and accepts the Magnum spoolgun. Would be glad to investigate if you desire. weldersales
Reply:Is this the gun you are thinking of? http://www.mylincolnelectric.com/Cat...eet.aspx?p=578weldersales
Reply:Yes, I do believe so. How much does he want for it? |
