MIG or Stick for my first training.
发表于 2021-8-31 22:28:23 | 显示全部楼层 |阅读模式
I have some experience with MIG welding a long time ago and I am going to school to train in welding. I was considering pursuing MIG since I would love to want to get back into the automotive sector, I enjoyed fabricating for Jeeps many years ago.  However it seems to be more of a demand and better pay for those who do Stick.  I have a family to take care of so would it be a better option to go Stick first then work on MIG/TIG?  Stick and MIG take about the same time to complete at the school and the cost is around the same as well.  If I had the time I would just have gone TIG, but time constraints are not allowing it atm.
Reply:Stick/tig/mig. Once you learn stick MIG becomes 100 times easier.Miller Maxstar 200 SDPiperliner #10 Gold
Reply:Originally Posted by smilexelectricStick/tig/mig. Once you learn stick MIG becomes 100 times easier.
Reply:Stick is a more difficult process to learn and master and also more well paying jobs if you are good at it.    TIG is the same way . both pay better because they are harder to learn and master   MIG is just bottom tier production welding for the most part.  check out  the channel for Fieldres on youtube if you want to see some talanted Stick/TIG workTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Oxygen & acetylene welding is the best to start out on. It will teach you puddle control. Then it’s easier to learn how to read the puddle, and learn to anticipate what you need to do to make corrections.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Based on what you're saying what you plan on doing with it I would go for a Millermatic 212 with .030 ER70S-6 wire and a bottle of 75/25 argon co2 mix gas.
Reply:Originally Posted by FyreTexI've had more than a few welders tell me the same thing. Why is that?
Reply:Originally Posted by BD1Stick involves more movement of hand / arm. With stick, the rod burns off . As it disappears you are required to move hand/arm to maintain the proper arc length. The rod continues to get shorter so you need to adjust for this with hand arm adjustments With mig, normally you can position yourself once and just move along. The nozzle is held basically in the exact same position and the wire keeps on feeding. Some guys will set the nozzle on the material and just move along as the wire exits the gun. So you are basically just watching the puddle and the nozzle just sits there.
Reply:Ok, Stick it is, then TIG.  Nice thing is, the machines I am looking at do TIG/Stick.
Reply:Stick really teaches you the 4 basic fundamentals well...amperage setting, arc length, angle of electrode, and travel speed.   If any of these are not set / performed reasonably accurately, the bead will reflect it. Stick is a very basic process that will serve a weldor well over the years because it can get into tight places, and doesn't require a shielding gas.As with any welding process, you have to practice your butt off.Rich
Reply:The stick class is 5.6 months 3400$ 24hrs a week, used to be 40hrs a week, $3k and only 3 1/2 months, but our college district has gone through a lot of changes, many for the worse.  385 out of the 542 hours is just welding, the rest is split between OSHA training, computer training (Already have lots of those done), Oxy-fuel cutting and a few other things squeezed in.  Is that worth it?  Should I still invest in a welder and gear for home?http://www.maricopaskillcenter.com/s...us-welding.pdfLast edited by Jellyroll; 09-07-2015 at 06:13 PM.
Reply:Those questions can only be answered by you...Rich
GMT+8, 2025-12-31 23:59 , Processed in 0.144095 second(s), 18 queries .
