Put it back together:
发表于 2021-8-31 22:28:21 | 显示全部楼层 |阅读模式
I've ordered a couple of replacement headgear for my old Phantom XL series hood by Sellstrom. After deciding I really didn't like the service replacement parts, I just melted the original back together. It's been used a couple of times since but I'm going to melt some more material, (PVC) plastic over the seam now that I'm thinking of it for reinforcement.Can't believe it only served me well for 19 years and decided to break. Damn the luck....SlobPurveyor of intimate unparalleled knowledge of nothing about everything.Oh yeah, also an unabashed internet "Troll" too.....
Reply:Where'd you put your ground at?
Reply:Originally Posted by big wormWhere'd you put your ground at?
Reply:Originally Posted by SlobI welded it the same way I welded the neck onto my three axle semi trailer, I used a Harbor Freight soldering iron. It's actually an "Ungar" iron and many years old. Proper grounding is so overrated I didn't use one......
GMT+8, 2025-12-31 20:31 , Processed in 0.100504 second(s), 18 queries .
