Using aluminum spool gun on a SA200 Lincoln or Weldanpower.
发表于 2021-8-31 22:28:21 | 显示全部楼层 |阅读模式
I would like to know what it would take to setup a Aluminum Spool Gun on a SA200 Lincoln or a Weldanpower 225-210 Lincoln?I would like to know also what Spool Gun to use also.Thanks,Walter
Reply:The Miller Spoolmatic 2 with WC 3 control is specifically for CC machines. Can't tell you how well it'll work from any personal experience, but it's designed for it.Expert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:Originally Posted by 7A749The Miller Spoolmatic 2 with WC 3 control is specifically for CC machines. Can't tell you how well it'll work from any personal experience, but it's designed for it.
Reply:Originally Posted by noriteI didn't know that.  I would have responded that you need a CV welder, which neither the sa200 or weldanpower are.  Good catch (as usual)
Reply:My Weldanpower does have CV so it might be better for the Spool Gun over the SA200.I am looking for the best way to do some aluminum in the field.For non critical work I use the Aluminum Stick Rods and they make it easy, but if it needs to be of better quality I tack the parts with the stick rods and take it back to the shop to TIG weld.
GMT+8, 2025-12-31 20:30 , Processed in 0.116281 second(s), 18 queries .
