"THE GIANT'' revisited
发表于 2021-8-31 22:28:17 | 显示全部楼层 |阅读模式
visited the "THE GIANT " after 10 months of being installed --do some maintenance check up..well aside from missing roots on the tree its holding, and some scratches on the inaugural marker...everything seemed to  looks good. no major rust build up yet ... i guess the applications  i did works well and i hope on my next visit--it will be the same and still on its "almost" perfect condition. CheersMario Attached Images
Reply:Well, don't let rust get a foothold.  It's always easier to renew a coating than to get down below rust that has started.  What coating were you using on that piece?"USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:Originally Posted by OldendumWell, don't let rust get a foothold.  It's always easier to renew a coating than to get down below rust that has started.  What coating were you using on that piece?
GMT+8, 2025-12-31 22:38 , Processed in 0.072464 second(s), 18 queries .
