Some pipe fab
发表于 2021-8-31 22:28:16 | 显示全部楼层 |阅读模式
[ATTACH]745051[/ATTACHStart to a metering station. I'll get more pics as I get farther along. Attached Images
Reply:Cool man, always look forward to your projects. Always top notch work! I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Hey Spec, where you at nowadays?Last fall I flew over SE Wy, then again a few weeks ago.  There had to be over 700 new well heads!  Near as I could tell it was South of Evanston/Rock Springs, maybe in Utah or NW Co.Sent while hiding at work using Tapatalk Lincoln SA 200Esab Caddy 160Thermal Arc 201TSMiller Dialarc HFI don't like making plans for the day because then the word "premeditated" gets thrown around the courtroom....
Reply:You sure do some nice work, is all of that pipe normally done with stick?TOO MANY TOOLS & NO MORE SPACE
Reply:Yes it is al stick. 6010 bead and 8010 out. Fill pass ready to cap
Reply:Dubl t I am working in El Paso at our yard. Finally home for aWhile.
Reply:Capped out. I didn't have time to brush it yet. Will tomorrowThanks. I wish I could weldAs good as a couple of the guys I work with.They flat a$$ can weld.
Reply:Make sure to use a hand brush (FieldRes)  Keeps the crows awayAnyways, I like what you do, mainly because I CAN'T do it.  You got the touch"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Nice !!!    I like those 300 pound flanges too !  Brings back memories.
Reply:How do you like those Pandjuris Missouri Mules in the background.
Reply:Colons stark. I can't comment on the mules. I never use them. We use them mainly to rollout larger pipe like 36 and 42 inch. BD1 those are 600 pound flanges.Not sure I have "the touch" but i still have fun doing it. I like working on lines more then fabrication in the shop. I still run my vantage like it better than the shop junk we have.
Reply:I got a set with a 3/8" 2205 super duplex 8'x13.5' tank and they are happy to roll it.  We also have a set that are good to 30ton.
Reply:Originally Posted by specopswelderColons stark. I can't comment on the mules. I never use them. We use them mainly to rollout larger pipe like 36 and 42 inch. BD1 those are 600 pound flanges.Not sure I have "the touch" but i still have fun doing it. I like working on lines more then fabrication in the shop. I still run my vantage like it better than the shop junk we have.
Reply:Another little piece ready for X-ray Kinda hard to see the welds. They are upside down so I could put the thread o let on the bottom
Reply:Three bead cap on some .688 wall 12 inch.
Reply:Some heavy wall
GMT+8, 2025-12-31 22:22 , Processed in 0.115192 second(s), 18 queries .
