lincoln sam 400 parts
发表于 2021-8-31 22:28:15 | 显示全部楼层 |阅读模式
Iam parting out a sam 400,   Continetal  6 cyl, 245 engine,  engine parts,...head,  distrubitor, starter,  govenor,  oil filter  alternator,  radiator ,  carburator,  air cleaner, and a like new  R57  throttle control, .... SHEET  METAL,  all 4 doors,  hood,   control pannel,  radiator cowel,  Control panel is complete as we speak,  but might not be long,  more pics on request,  Thanks Eric Attached Images
Reply:Wonder if that R57 is the same as the one on a sa200 ?  What are you asking for it ?
Reply:Originally Posted by Showdog75Wonder if that R57 is the same as the one on a sa200 ?  What are you asking for it ?
Reply:i need the sheet metal. the starter and face plates. 432-889-8852
Reply:where do u order filters for this machine?
Reply:i realy need the sam 400 parts email me back with a price or cal me anny time thanks . 432-889-8852
Reply:wires # 2 #8 #21 #31 # 32 are not hooked up and the welders alternator is not hooked up eather. anny help please Attached Images
Reply:My guess is the original alternator was replaced with the current unit thus negating the need for the original seperate voltage regulator (per unit parts break-down) that was probably mounted here . . . . . and I suspect the alternator output wire goes here.  ??MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:thank you.
Reply:thair is a long black wire comming from the amperage dial that is about 2 ft long hanging down as well
Reply:Where does the wire on the other side of the ammeter go?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:i dont see anny wires going to the amp meter
Reply:I'm sorry - I misread "amperage dial" for ammeter (amp gauge) because we were talking about the engine alternator. MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:my welder only runns for 30 seconds then slowly dies . anny ideas. i replaced fuel line from tank to filter. and replaced the oil filter and changed oil. also put sea foam in the gas tank
GMT+8, 2025-12-31 22:21 , Processed in 0.105952 second(s), 18 queries .
