Wanted: Manual Bender
发表于 2021-8-31 22:28:15 | 显示全部楼层 |阅读模式
I'm looking for a manual tube bender, something along the lines of a JD2 model 3. I was gonna order a new one, but figured I'd see if anyone wanted to sell a used piece. Thanks
Reply:Where are you located?
Reply:Rochester NY
Reply:check out jmr sportsman its only 195 till the end of the month. http://www.jmrmfg.com/featured-tools...n-tube-bender/
Reply:i have a model 3 manuel bender with about 6 or 7 dies , (cant remember) i used it to build a roll cage. now i have to move and i wont have a garage to put it in so im thinking of selling it. pm me and ill give you my phone number if your intrested.
Reply:What's the big difference between the JD2 #3 and the JRM manual tuber benders?  The look and operate almost identical from what I see. JD2 #3 is $295 and the JRM is $395.StephenMillermatic 251Miller Syncrowave 200Miller 30A SpoolgunHypertherm Powermax 30Etc., etc., etc.............Cancer Sucks!
Reply:Bushings precision ground arms heat treated and black zinc coated also couple other things they said when i purchased mine.
Reply:I also have a got trikes diy bender im going to be selling.I just built it this month  then the jmr came on sale. I wanted to be able to bend 2.5 in tube I got got about 275$ in the got trikes with out dies i would sell for $400 with air/hydro set up with all the pins  and painted or 300 no  hydro, paint and pins the site to the bender is www.gottrikes.com Its a nice way to go if you have the time I have allot of time in it. I'm from central pa so might be into traveling alil bit for right price.
GMT+8, 2025-12-31 22:22 , Processed in 0.097822 second(s), 18 queries .
