查看: 13|回复: 0
Miller Dynasty 300 price , hours and arc strikes
发表于 2021-8-31 22:28:12 | 显示全部楼层 |阅读模式
OK here is the deal , I have the chance to buy a dynasty 300 welder for around 2500 dollars , thing is I'm in Mexico , and not a lot of people know about these welders , so i come here for some info and opinions.Link to the actual welderhttp://san-nicolas.anumex.com/anunci...ynasty/7974796He states that the machine works on 440 volts , but i can barely tell that it also works with 220 volts.. ( I'm hoping it works with single phase , thats what i have in my shop).He does not state what model it is... But from the pictures I'm guessing its a Dynasty 300 with a coolmate 3 on the bottom.How many hours is to much hours before i have to face replacing circuit boards worth 1000'sHow many arc strikes are way too much ( This welders seems it came out from a production line o serious welding shop , you can tell be the "TIG 02" sticker on the side in the first picture).I"m welding AL , so I'm guessing this machine is ideal for my purpose .Let me know what you think! Thanks again to this great forum!
Reply:Look on the miller site.  Do a search for "Dynasty 300".  There's a thread on it where Cruiser, the resident electrical guru and repair tech, states that no one should buy one.  They're getting old and parts are becoming scarce in his opinion.  I agree, it doesn't seem like that bad a deal, especially if you could get him lower.  I'd personally step away.The SN dates that machine to a 1999 build date.Last edited by Drf255; 04-04-2014 at 05:03 AM.Reason: Added content.
Reply:Where can i do a history check on the powersupply ? the SN is KK032487
Reply:Here is a date chart.http://www.millerwelds.com/service/s...reference.htmlThat thing looks pretty abused. I can't imagine it is in good operating condition. Would be a shame to buy all the peripherals and find out it is fried. The cooler may be worth $400, so they are essentially asking $2100 for the Dynasty. Not good IMO.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Originally Posted by shovelonHere is a date chart.http://www.millerwelds.com/service/s...reference.htmlThat thing looks pretty abused. I can't imagine it is in good operating condition. Would be a shame to buy all the peripherals and find out it is fried. The cooler may be worth $400, so they are essentially asking $2100 for the Dynasty. Not good IMO.
Reply:Originally Posted by LimeweldI have all the peripherals.. the tig torch the gas cylinder plus flow meter , the tig pedal etc , do you think its worth the buy? I have a thermal ARC 300 GTS with a miller coolmate 3 but it does not have the AC function Im looking for .....So im selling this machine to buy the other one .... Am I on the right track?Thanks to all for your responses!
Reply:The welder is a Dynasty 300DX Left factory around  02/16/1999.The design is like the xmt304. you have a 15 year old welder. Unless the inverter caps have been replaced they are near end of design life. Could fail at any time.Yes it will work on either 230 or 460 volts. single or three phase. Max out put is limited to 200 amps on single phase power. Do to components for the pc boards going obsolete and changes in other parts some parts may no longer be available. It would take a call to Miller tech support and ask what parts are available and for how long.Do not buy unless you can power it up. All you need to do is change the plug to change the voltage it runs on. The welder will auto link to 230 or 460 volts.If the line cord is still connected like it came from factory, tape up the red wire in the line cord for single phase power. Black and white must have  line power on them for the welder to turn on.You may even what to pull the cover off first and give it a close look over.If the big capacitors are white . you will want to replace them right away, the kit is $200 to $300 . Make sure you put the cover back on before powering up. If some thing shorts and explodes, electrical fire and plastic parts can come flying out at high speed.You are looking at a welder that could last another 10 years or blow up next week. You have to know what you are willing to risk on a welder with a lot of bells and whistles.You may want to pass on this one and look for a syncrowave 250. Simple basic AC/DC TIG welder.
Reply:Originally Posted by ccawgcThe welder is a Dynasty 300DX Left factory around  02/16/1999.The design is like the xmt304. you have a 15 year old welder. Unless the inverter caps have been replaced they are near end of design life. Could fail at any time.Yes it will work on either 230 or 460 volts. single or three phase. Max out put is limited to 200 amps on single phase power. Do to components for the pc boards going obsolete and changes in other parts some parts may no longer be available. It would take a call to Miller tech support and ask what parts are available and for how long.Do not buy unless you can power it up. All you need to do is change the plug to change the voltage it runs on. The welder will auto link to 230 or 460 volts.If the line cord is still connected like it came from factory, tape up the red wire in the line cord for single phase power. Black and white must have  line power on them for the welder to turn on.You may even what to pull the cover off first and give it a close look over.If the big capacitors are white . you will want to replace them right away, the kit is $200 to $300 . Make sure you put the cover back on before powering up. If some thing shorts and explodes, electrical fire and plastic parts can come flying out at high speed.You are looking at a welder that could last another 10 years or blow up next week. You have to know what you are willing to risk on a welder with a lot of bells and whistles.You may want to pass on this one and look for a syncrowave 250. Simple basic AC/DC TIG welder.
Reply:Originally Posted by Drf255Look on the miller site.  Do a search for "Dynasty 300".  There's a thread on it where Cruiser, the resident electrical guru and repair tech, states that no one should buy one.  They're getting old and parts are becoming scarce in his opinion.
Reply:hit and miss....That's life.Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Hi ccawgc,"ccawgc  WeldingWeb Artisan… Unless the inverter caps have been replacedYou may even what to pull the cover off first and give it a close look over.If the big capacitors are white . you will want to replace them right away, the kit is $200 to $300 . …"Thats a Very Interesting Comment…as I did a visual on mine and I do have the white caps installed on my maxstar 300dx unit, so what colour are the replacement caps in the kit as my Miller rep admitted they never brought that model at their location, just the xmt's , so I and them would know what to look out for?David
Reply:http://articulo.mercadolibre.com.mx/...dar-miller-_JM other post the guy made , (mexican ebay)
Reply:The first caps used were all white with black writing. quite a few years ago they switched brands and they are blue. At least with the dynasty 300 the old caps and the new caps are the same size.On a xmt304 when you replace the white caps you have to replace the mount also.
Reply:Hi ccawgc,Thanks for taking the time to update me on what to look out for in the caps.Appreciate the info so i can keep the old gal running!RegardsDavidHey Limeweld, i almost forgot to mention but what you are looking for just popped up on ebay yesterday with LOW HOURS, seller is willing to ship and the serial# he said is a LE ******. Price …well he's taking offers too! Already 3 watchers
Reply:Here are some pics that the seller sent me .
Reply:Hey Limeweld,Thanks for posting those pics of the dynasty300,But which dynasty do these pics refer to? The mexico one you were interested in or the ebay one?Also did you have to resize the pics smaller to post up or are these the original size?From what i'm seeing using my old cell it looks pretty clean insideRegardsDavid
Reply:naa crappy cel phone pics the guys sent me , the ebay one i could not find , all pics , mexican ebay (mercadolibre) and other links are of the same machine in question .
Reply:Hey Limeweld,Ok i just finished typing a pretty long post and touched the wrong button using the cell and wound up loosing everything i typed…Damm iphone.So to cut to the chase the first 2 #s are of the dynasty reposting and finally ending 27aprilAnd the 3rd and 4th #'s are of two different auctions of different manufacturer old school digital inverters i used in 2001 at a former boss yachtie repair business- worked great on aluminum tubing for railings and bimini topsThe last one is unit only with a lot of seller instructions and time and date of inspection yada yada local pickup onlyAnd lastly change your ebay search settings to "business and industrial" and also change the menus to either " newly listed" or "ending soonest" if you leave the menu to ebays " best match" youll be searching through a Lot of unnecessary crap to get to them251510913863251517151982181393451585271471819413Enjoy
GMT+8, 2025-12-31 22:21 , Processed in 0.097553 second(s), 18 queries .
