bending round bar to form a circle
发表于 2021-8-31 22:28:08 | 显示全部楼层 |阅读模式
Hi we are making tables in our welding shop , 54" and 37" round bar for the body of the table.Problem is im terrible at perfecting the circle bends, i bend the bars on the jigs and get the rough circle shape but i have to get the end part of the bar to curve in to meet the other end.Anyone got any tips for this? im using a pedestal bender for the bends.
Reply:Bend more than the full circle and cut the straight ends off.Leo
Reply:Originally Posted by NVWBend more than the full circle and cut the straight ends off.
Reply:I've actually never used a roller, but how well would it work if you rolled it, welded the ends together, ground the weld flush, and re-rolled completely around to smooth out the flat. Dynasty200DX w/coolmate1MM210MM VintageESAB miniarc161ltsLincoln AC225Victor O/A, Smith AW1ACutmaster 81IR 2475N7.5FPRage3Jancy USA1019" SBAEAD-200LE
GMT+8, 2025-12-31 22:20 , Processed in 0.095392 second(s), 18 queries .
