What are those "snap lock" thingy's called?
发表于 2021-8-31 22:28:08 | 显示全部楼层 |阅读模式
Can someone tell me what the technical term is for those pins that pop up when an opening in a larger round tube slides over a pin in a smaller round tube? Thanks.
Reply:Som beotches or those mofos or perhaps dohickeys , possibly thingamajig , whatcha ma callit In all seriousness i have no clue , picture ?I forgot how to change this.
Reply:English as a second language?Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:Here's a pic - this one is some spring steel with a "lock pin" punched in it. Attached Images
Reply:Button Locks or Ball Plungers.Here's a link:http://www.jwwinco.com/products/sect...#ball-plungersEric
Reply:Hmmm. I checked the link. Looks different.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:I found out that the technical name is "Snap Button".http://www.valcocleve.com/snap-button-a.htm
Reply:If you want plastic ones, check out swimming pool supply companies.  These are used on most pool cleaning tools...brushes, nets, etc...to attach to the telescoping utility poles.I've probably got a dozen of 'em.Miller 211 w/ spool gunMiller Dynasty 200DXLongevity 60i IGBT plasmaO/A w/ crappy chinese torch/gaugesSouth Bend 10K latheGrizzly 4029 10x54 millGrizzly 7x12 hor bandsawangle grnders, bench grnder, bench belt sndr7.5 hp 80gal cmprsor
Reply:I called them jesus clips cause when the come loose while using the wrong too and zing across your face you scream Jesus.
Reply:Originally Posted by BTDIf you want plastic ones, check out swimming pool supply companies.  These are used on most pool cleaning tools...brushes, nets, etc...to attach to the telescoping utility poles.I've probably got a dozen of 'em.
Reply:They are called quick release button connectors.  I have used them for projects before and I get them from McMaster-Carr.  Here is a link: http://www.mcmaster.com/#tube-connector-pins/=dbgz65
GMT+8, 2025-12-31 20:31 , Processed in 0.108035 second(s), 18 queries .
