Cut off wheels?
发表于 2021-8-31 22:28:06 | 显示全部楼层 |阅读模式
I use my cut off tool quite a bit, you know the air tool that is like a die grinder but with a thin kerf disc 3-4 inches diameter.  I use Forney discs because they are readily available in my area. What are others using and how well do they work, where do you get them?"Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:I got some off Ebay (10 pack) and man were they rough. I had to clean out the center hole before I could mount them BUT man did those sucker cut and with slow ware down. They are a great little tool.Lincoln SP135-TFirepower FP-235AC/DC
Reply:They make them for grinders too in all sizes.   i usually use zip wheels on my 5" grinder.   Still able to get into corners and make deep cuts faster with a lot more control.When fitting plates we use strongbacks (5/8"plate or thicker that has been skip welded) to keep two plates from distorting when being welded.   When it comes time to cut them off I'm done in a few minutes vs 20 min of grinding.“I'm going to do the thing that God put Galen Beasley on this Earth to do:Have Salon quality hair and weld.Nothing like a good cup of coffee and the smell of 6010 burning in the morning. 971-204-3444 cell API ASME Structural NDT and Repair
GMT+8, 2025-12-31 20:30 , Processed in 0.098278 second(s), 18 queries .
