Speedfreak's Filler Necks...Round 2...
发表于 2021-8-31 22:28:05 | 显示全部楼层 |阅读模式
Hey Speedfreak..I got all 10 done this A.M.Took about 1 hr. to do them all after I got the machine set up the way I like it..They are a little different than the first one I made you but they were much easier this way and now you will only need a 1 3/4" hole for them..We will call this "Revision A"..I'll be in touch!...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Hmmm.. I kind of like the other one more, the lip fills the space in between the bottom of the cap and the top of the tank. http://weldingweb.com/vbb/showthread.php?t=57578http://weldingweb.com/vbb/showthread.php?t=57655www.thefusionsolution.com
Reply:That may be true BUT the seal is at the bottom of the cap (Inside)and it seals perfectly with the top of the neck..The lip is not really needed in all reality..I did'nt have any 2.5" stock that I made the first one out of so I used 2"..It's all I have..And a new piece of tubing comes 20 feet and I don't think you want to buy all that.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:That's a valid point. lol!www.thefusionsolution.com
Reply:Oh, and nice job!Tim Beeker.
Reply:What's the total length from the bottom of the step to the top of the threads?www.thefusionsolution.com
Reply:Originally Posted by speedfreak87What's the total length from the bottom of the step to the top of the threads?
Reply:You do good work ZapMaxus Pro-125 MigChicago Electric 90 amp DC flux-coreLincoln Electric AC 225 tombstoneO/A torchM/O mini-torch10 acres of flatland15 acres of holler
Reply:Originally Posted by dugndeepYou do good work Zap
Reply:Originally Posted by zapsterI can always shorten them up if need be.....zap!
Reply:Will do.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Thanks!www.thefusionsolution.com
Reply:I'll post pics of "Revision B" when I get home.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Rev.B pics..The O.A.L. is now 1" and you have the 1/8" step on the bottom..I will give you a call sometime tonight.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Very nice, good work!BTW, Zap, where are you located?
Reply:Mass. R.I. border..I can be in R.I. in 4 mins.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Now lets see him weld it in and not jack up all the lathe work! lolLincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Originally Posted by Joker11Now lets see him weld it in and not jack up all the lathe work! lol
Reply:Originally Posted by BoostinjdmThat's what I was thinking.  Better weld it on the inside.
GMT+8, 2025-12-31 22:22 , Processed in 0.106107 second(s), 18 queries .
