wg3020 mig machine specs
发表于 2021-8-31 22:28:03 | 显示全部楼层 |阅读模式
I'm looking at an add for a used Lincoln mig machine model WG3020.can anyone give me any specs for this machine?
Reply:After some research, i believe the add is incorrect, I believe the unit is a Campbell Hausfeld machine which is why i could not locate any info on it.
Reply:Do you see any problem with the CH machine.  JOhnSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:Other than the fact the add has the machine misslabled, no, no problems.
GMT+8, 2025-12-31 20:31 , Processed in 0.101541 second(s), 18 queries .
