simple welding project
发表于 2021-8-31 22:27:57 | 显示全部楼层 |阅读模式
This is about the easist welding project to do. It comes in very handy when setting grade, or building a square. The rebar holds the string tight with its ribs. It's also very cheap. I was tired of always pounding a piece of wood in the hard Missouri ground. After a day of use they were trash. The project does not need to be pretty, just very strong welds.4) 20' sticks of 3/8's rebar $20.00Cut each stick into 3' and 2' pieces. Lay them on top of each other and weld away.
Reply:I'm not seeing the attached picture?Lincoln Power Mig 216Lincoln AC/DC-225/125Miller  625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita  Baileigh NRA Life Member
Reply:Originally Posted by SuperArcI'm not seeing the attached picture?
Reply:It's one of those hidden pictures.  If you stare at it long enough you'll see it.
Reply:I think you attached a picture with a wrong format /  unsupported format.PlasmaCam CNC cutterLathe and Band SawClamps
GMT+8, 2025-12-31 20:31 , Processed in 0.100876 second(s), 18 queries .
