Livestock trailer
发表于 2021-8-31 22:27:57 | 显示全部楼层 |阅读模式
I built this, certified to carry 8500 pounds. A hellavu job if you do everything alone. Sometimes I wonder why do I accept so much work. Unfortunately I've got only one pic on my mobile because my other one got stolen before I could download.
Reply:Caper-van-NiekerkWelkom / weerWhat is:  the trailers special function?Opus.Last edited by OPUS FERRO; 06-28-2014 at 01:25 AM.Reason: Too few Diphthong & Phonomes.
Reply:If I tried using an open framed trailer like that I would be dealing with broken legs on cattle and horses.  Stock trailers around here are solid up to head level or has slats small enough to keep legs out.  If it works for you that is what matters.  Looks pretty good.DanManipulator Of Metal
Reply:What is: the trailers special function?I  made this to order, the owner use it for general farm transport.Re: Livestock trailerIf I tried using an open framed trailer like that I would be dealing with broken legs on cattle and horses. Stock trailers around here are solid up to head level or has slats small enough to keep legs out.If it works for you that is what matters. Looks pretty good.DanThanks Dan. I made the centres of the bottom pipes 4 inches apart. But it would have been better with solid sides.
GMT+8, 2025-12-31 20:30 , Processed in 0.101107 second(s), 18 queries .
