Lincoln Welder Power MIG® 350MP Push Model
发表于 2021-8-31 22:27:49 | 显示全部楼层 |阅读模式
MAKE ME A REASONABLE OFFERBRAND NEW...NEVER BEEN USED!...Just a little dusty from being in the warehouse.For details regarding this specific unit please reply to this ad or call/lvm @ 281.300.4000Product Name Power MIG® 350MP Push Model 208/230/460/575/1/50/60Product Number K2403-1Input Power * 208/230/460/575/1/60Rated Output * 300A/32V/60%Input Current * 76/64/37/29AOutput Range * 5-350A DCDimensions (H x W x D) 31.8 in x 18.9 in x 38.8 in (808 mm x 408 mm x 985 mm)Cored Wire Size Range .035-.045"Net Weight 255.000 lbs. (115.668 kg.)Power MIG®. The Professional's Choice.When you need more than just a MIG machine, the Power MIG® 350MP is the choice for you. Lincoln Chopper Technology® delivers more welding processes — MIG and flux-cored, along with excellent stick welding, TIG and advanced processes such as Power Mode™ and Pulse-on-Pulse®.* Lincoln Chopper Technology®® - Delivers high quality welds by increasing the control over the welding arc.* Multi-Process Capable - Welds MIG, flux-cored, stick, TIG, pulsed MIG, and advanced processes like Pulse-On-Pulse® and Power Mode®.* Pulse-on-Pulse® - Improves cleaning action when welding aluminum and delivers a TIG-like appearance to the weld bead.* Power Mode® - Maintains a stable, smooth arc for short arc welding on thin material – great arc length control for aluminum welding.* Synergic control - Allows you to set weld procedures with only one control for simplicity.* Rugged cast aluminum industrial wire drive - Features dual driven rolls, easy-turn numeric tension indicator, brass-to-brass gun connections and Lincoln’s 100% wire-supporting split wire guide system.* 3 Ways to Feed Aluminum - Choose a Push Gun, Spool Gun or Push-Pull Gun to feed aluminum. The Power MIG® 350 has the electronics build-in for all three methods - no PC board add-ons are requiredPLEASE USE THE FOLLOWING LINKS FOR SPECIFIC ITEM DETAILShttp://www.lincolnelectric.com/en-us...roduct=K2403-1http://www.lincolnelectric.com/asset...403-1/e757.pdf Attached Images
Reply:It is courteous to post the specific details in the ORIGINAL advertisement, not just factory info anyone can Google. Post the Serial number and Code number for Lincoln machines.Doing otherwise is a bit spammy.
GMT+8, 2025-12-31 20:29 , Processed in 0.114948 second(s), 18 queries .
