Critique, stick
发表于 2021-8-31 22:27:46 | 显示全部楼层 |阅读模式
100 amps 3/32 7018. Rods from an open boxhttp://fucdatbirth.blogspot.com/
Reply:I'm a novice so take it for what its worth.  Why no metal prep?  Jerry30+ yrs Army Infantry & Field Artillery, 25 yrs agoMiller 350LX Tig Runner TA 210, spool gunLincoln 250/250 IdealArcESAB PCM 500i PlasmaKazoo 30"  vert BSKazoo 9x16 horiz BSClausing 12x24 lathe20T Air Press
Reply:I ground off where the welds were. Figure i dont have to go nuts with arc weldinghttp://fucdatbirth.blogspot.com/
Reply:Here is some mild steel tig, 90ampshttp://fucdatbirth.blogspot.com/
Reply:IMO the arc welds look cold other than that not too badThermal arc 211iCk flex-loc 150 & 130Clamps, saws & grindersHarbor freight 80 amp inverter
Reply:All of them? The first 2 i did horizontal, mainly because i wanted the practice, i could have turned the piece, i feel like it looks cold but as i was doing it the puddle was drooping, im at a loss, wouldnt hotter make it droop more?http://fucdatbirth.blogspot.com/
Reply:I'm just a backyarder so take it with a grain of salt, but with out of position welds like the first two, I'd either try running hotter and faster with a slight upwards angle (5-10 degrees) or find another rod. Some rods I've used just aren't suited to out of position because of the slow freeze and sagging.
Reply:You need to clean the joint better, especially  for 7018.  Shiny steel is what you want.Lincoln Power Mig 216Lincoln AC/DC-225/125Miller  625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita  Baileigh NRA Life Member
Reply:Yes they all look cold especially the first two. You are welding really thick material. Try 1/8" rods 130-150 amps and speed up. Literally push the rod in the puddle. What kind of welder are you using ?
GMT+8, 2025-12-31 22:22 , Processed in 0.100712 second(s), 18 queries .
