Tri Arc 160
发表于 2021-8-31 22:27:45 | 显示全部楼层 |阅读模式
Hello fellas,  I wonder if I can find info about Tri Arc 160 welder I mind go trade these welder  I'm very curious to learn tig anybody know how capable are Tri Arc 160?I have this info:Brand: Mid State Welder ManufacturingModel: Tri Arc 160Code number: 0114Serial numberG906105Stock number: 7846-0017Its a 230 volt welder that can do MIG, TIG, and arc weldinf, comes with the mig and arc welding attachments How easy are to find the parts or attachment for tig?  Thanks for any advice!  Sent from my iPhone using Tapatalk 2Millermatic 212
Reply:Did you get this welder hooked up? I have the same welder. I have had it for bout 16 years and have never had any issue's. mine also has a stitch mode. The tig is very smooth and will turn down to next to nothing. Very simple, and easy to switch from mig,arc, or tig.
GMT+8, 2026-1-1 00:21 , Processed in 0.073571 second(s), 18 queries .
