here are the pics what you think ESAB Dual shield 7000 .45thats a big gun its a Bernard QT3-45Lincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:come on 9 views leave some comments lolLincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:are you selling it or did you buy it? its a good deal if it works at $400. My 300avs is in the same pelican case. only problem is the handles seem to break off. I used an aluminum grab handle of the side of a semi. it spans the length of the case and u can use 2 hands to pick it up. . I think when these are loaded with a 44lb spool of wire they are probably over the designed capacity of the handles... I bought 2 broken 300's and made one good one and both had the handles missing.Tiger Sales: AHP Distributor www.tigersalesco.comAHP200x; AHP 160ST; MM350P, Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma. For Sale: Cobra Mig 250 w/ Push-pull gun. Lincoln Wirematic 250
Reply:just got it for 400 good to know about the handles ill be careful when i pick it up oh yeah everything works in itLincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:looking at your signature, now you are going to need a machine with more DC amps to run that feeder effectively. I got a couple perfect machines in my sig for you.250 DC amps via the 200SM and 375DC amps via the 300SM and both are CV and CC machines...Tiger Sales: AHP Distributor www.tigersalesco.comAHP200x; AHP 160ST; MM350P, Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma. For Sale: Cobra Mig 250 w/ Push-pull gun. Lincoln Wirematic 250
Reply:Oh here is a pic of my setup and the handle. The 400amp euro connector make it look like it's hung like a horseTiger Sales: AHP Distributor www.tigersalesco.comAHP200x; AHP 160ST; MM350P, Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma. For Sale: Cobra Mig 250 w/ Push-pull gun. Lincoln Wirematic 250
Reply:Nothing quite makes your day like a really good deal.Congratulations!
Reply:SLICK use of the semi grab handle. I'll have to get one for my Hobart Hefty. The stock handle is tiny.Great price on the feeder.
Reply:Very nice man!! Ill give you $401 for it [Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:nice. I got a helluva deal on mine as well. Barely used and came with a Brand spankin new Bernard S40 gun. I use mine almost everyday. Wish it would work with the stick welder at home but the inverter doesn't seem to like it too much.I'm runnin mine off a Bobcat for field repair stuff. Lot easier running FC than stopping every 8" to throw in a new stick. Plus it seems to be a lot easier on the flux cleanup. Nice score on it
Reply:Originally Posted by BCTimberwolfnice. I got a helluva deal on mine as well. Barely used and came with a Brand spankin new Bernard S40 gun. I use mine almost everyday. Wish it would work with the stick welder at home but the inverter doesn't seem to like it too much.I'm runnin mine off a Bobcat for field repair stuff. Lot easier running FC than stopping every 8" to throw in a new stick. Plus it seems to be a lot easier on the flux cleanup. Nice score on it
Reply:Originally Posted by BCTimberwolfnice. I got a helluva deal on mine as well. Barely used and came with a Brand spankin new Bernard S40 gun. I use mine almost everyday. Wish it would work with the stick welder at home but the inverter doesn't seem to like it too much.I'm runnin mine off a Bobcat for field repair stuff. Lot easier running FC than stopping every 8" to throw in a new stick. Plus it seems to be a lot easier on the flux cleanup. Nice score on it |
