查看: 13|回复: 0
came across this
发表于 2021-8-31 22:27:44 | 显示全部楼层 |阅读模式
is it really that simple ???http://www.instructables.com/id/How-...-Cutter/#step1Lincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:The electronics is only one part.  The design of the torch head is a great deal of engineering.  The air of in some cases gas or combination of gasses have to swirl very rapidly to support the plasma stream.  The design of the electrode is another... Initial plasma designs used two gases and tungsten as the electrode.  Air systems use hafnium.   You might get a plasma stream but how long will the consumables last and what is the duty cycle of the electronics....  It is a good project if you are into designing things but you are not working with low voltages.  They are better than low... they can be lethal voltages.
Reply:i got a perfectly good thermal dynamics plasma torch im not using i switched to a newer style id sell ya lol.I forgot how to change this.
Reply:i love to build i would do one just for the fun of it lolLincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:I'm sure it will produce a plasma arc.....however there is no real current control and no electrical isolation for the guy holding the torch. I suspect it will cut some 26 gauge or so....just be careful not to get electrocuted!Jim
Reply:lol i willLincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
GMT+8, 2026-1-1 03:51 , Processed in 0.106483 second(s), 18 queries .
