Where do you get bandsaw blades?
发表于 2021-8-31 22:27:44 | 显示全部楼层 |阅读模式
I have a 7" x 12" bandsaw that uses 3/4" by 93" bandsaw blades.I can not find those anywhere. I need to cut some 1inch square .120" for my son and the blade broke. Even the ShipWreck Tool store doesn't have them on their website.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:And on second thought, how do you properly select bandsaw blades for the material? How many TPI is best to use on what? The blade that broke is gone now. The 14TPI that is on there can't be the right one at all to use. Seems like more TPI equals a nicer cut.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:http://www.mcmaster.com/#metal-cutti...blades/=di62hxThere are many distributors that can also make blades up to order for you, as well.Blackbird
Reply:Originally Posted by Joker11And on second thought, how do you properly select bandsaw blades for the material? How many TPI is best to use on what? The blade that broke is gone now. The 14TPI that is on there can't be the right one at all to use. Seems like more TPI equals a nicer cut.
Reply:You can buy a any pitch bandsaw blade in a spool and just make your own..Cut to length..Grind ends flat..Tig..Grind face flat both sides..Anneal...Done.Very handy when you need one NOW!!!!...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Dave,Thanks.Zap,Meh.....that sounds like a lot of work....lolLincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Dave,McMaster wants 150-260bucks for some of those blades? I thought a blade might be 25bucks max.Is that right?Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Originally Posted by Joker11I have a 7" x 12" bandsaw that uses 3/4" by 93" bandsaw blades.I can not find those anywhere. I need to cut some 1inch square .120" for my son and the blade broke. Even the ShipWreck Tool store doesn't have them on their website.
Reply:Zap, what filler rod would you tig with, or would use just fusion weld it? And how do you anneal?
Reply:Originally Posted by Joker11Dave,McMaster wants 150-260bucks for some of those blades? I thought a blade might be 25bucks max.Is that right?
Reply:Originally Posted by kustomizingkidZap, what filler rod would you tig with, or would use just fusion weld it? And how do you anneal?
Reply:No,$25 is not my breaking point. Was just a guess. The mcmaster site was quite different than most sites so maybe I wasn't looling in the right spot.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:I buy mine from a sharpening service.Bi metal run about 32.00 I built a jig to hold blades to weld my own and I tried it on an old blade.....worked pretty well.
Reply:Dave, you said to go 18-24tpi. I can't find one. I see the 14tpi.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Originally Posted by Joker11Dave, you said to go 18-24tpi. I can't find one. I see the 14tpi.
Reply:try www.use-enco.com ... use code FSR82 to get free shipping, i think the code is good till tomorrowESAB Heliarc 252
Reply:Ebay. I got some awesome bimetal blades from some saw shop in canada.Welding/Fab Pics: www.UtahWeld.com
Reply:Originally Posted by zapsterFused..Overlap them by about 1/16" with a aluminum backing plate..After grinding the face flat on both sides heat the area with a torch to a dull red and let cool by itself..If you can bend the weld area into a "U" after complete cooling without it snapping then you are good to go.....zap!
Reply:Originally Posted by AircamperaceDoes anyone have a picture of this they could post?
Reply:I use Echols Saw and Supply here in Phoenix.  Good quality blades, and they stand behind their work too.http://web.me.com/sawman1/EcholsSaw/...26_Supply.html---No good deed goes unpunished---
Reply:I have several spools of Lenox Blades of varying teeth and pitch configuration. I silver solder all of mine. Piece of cake. Have a fixture that works perfect.Gotta have the right silver solder, but it is perfect everytime.http://jackalopefab.com/MM210Synchrowave 200DXMiller XMT350 w/60series feederMiller Bobcat 250 with SGA 100 and spoolgunHTP PlasmaFull Machine shop with everything
Reply:Originally Posted by jackalopeI have several spools of Lenox Blades of varying teeth and pitch configuration. I silver solder all of mine. Piece of cake. Have a fixture that works perfect.Gotta have the right silver solder, but it is perfect everytime.
Reply:Where to get the right silver solder please?
Reply:Originally Posted by wayne55Where to get the right silver solder please?
GMT+8, 2026-1-1 00:20 , Processed in 0.100202 second(s), 18 queries .
