Source for new nozzle for Lincoln magnum 100L gun
发表于 2021-8-31 22:27:41 | 显示全部楼层 |阅读模式
I have a Pro Mig 180 and would like to get a couple replacement nozzles for the gun. Does anyone know a good source with good prices that has the factory replacement nozzle or one just as good.I bought a couple off ebay that are tweco 2150's I think and they are 1/4 in longer than the factory nozzle.
Reply:http://www.usaweld.com/products/index.htmBob WrightSalem, Ohio  Birthplace of the Silver & Deming Drillhttp://groups.yahoo.com/group/southbend10k/http://groups.yahoo.com/group/sawking/1999 Miller MM185 w/ Miller 185 Spoolmate spoolgun
Reply:Personaly i like tweco replacement parts over oem style as they tend to be heavier duty however to each their own.If you have no local weld supply shop(mom and pop type,stay away from airgas) www.ramwelding.com is a good one stop shop as well as others like usaweld,cyberweld....
Reply:if the only problem is they are too long, grind or cut the end down to the size you want..i had the same problem before and that fixed me up...good luckI wonder if I will be spanked for this one too!?!
Reply:Home Depot, Lowes or your LWSThe 100L gun is used on the 140s and 180s sold at all of these stores.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:Like Broccoli said, HD or Lowes -usually- have the nozzle(s) for the Lincoln Magnum100 gun.Copper GMAW nozzle and black FCAW nozzle.  By me, Lowes usually had a -slightly- better price and they were usually in-stock.  Nozzles and contact tips.  And about the best price on the 8" spools, NR-211MP 0.035 FCAW wire or L-56 GMAW solid MIG wire.  Depot was usually a few (single) dollars more, and LWS another 5-10 bucks higher than that.YMMV.
Reply:Originally Posted by 737mechanicI have a Pro Mig 180 and would like to get a couple replacement nozzles for the gun. Does anyone know a good source with good prices that has the factory replacement nozzle or one just as good.I bought a couple off ebay that are tweco 2150's I think and they are 1/4 in longer than the factory nozzle.
GMT+8, 2026-1-1 00:19 , Processed in 0.126588 second(s), 18 queries .
