Lincoln Weldanpower G8000
发表于 2021-8-31 22:27:39 | 显示全部楼层 |阅读模式
I have a Lincoln G8000 and have been using it to generate 220 power for a Hobart 187 mig welder.  Today I lost power.  Engine runs fine, but will barely turn a chop saw.  Suggestions??  Will a weak battery affect the generators output?
Reply:Battery has nothing to do with it once the welder is running.Do you need the fine control turned all the way up?That is all I have to help.DavidReal world weldin.  When I grow up I want to be a tig weldor.
GMT+8, 2026-1-1 00:20 , Processed in 0.099580 second(s), 18 queries .
