Truck bumper hitch for the mobs!!!
发表于 2021-8-31 22:27:37 | 显示全部楼层 |阅读模式
Reply:Have at her boys!!!! At auction tomorrow morning....
Reply:Originally Posted by 7A749Perfectly safe...Hey, the front end might fit on that other truck!
Reply:Not to worry. I'm sure it will ONLY be used to carry a bicycle rack, or step, and ONLY ever be used on private property. Right...IAMAW Local 330Airco 300 AC/DC HeliwelderAirco Dip-Pak 200 with Profax spool gunPowr-Kraft AC225Everlast PowerArc 200stBuffalo Forge No.21 drill pressSpeedglas 9100xxAirco, Oxweld, Purox, Victor torchesLincoln Ranger 8
Reply:Where's the mobs tonight???Thought this thread would be locked within 30mins....Disappointing.
Reply:Originally Posted by AKweldshopWhere's the mobs tonight???Thought this thread would be locked within 30mins....Disappointing.
Reply:Originally Posted by MinnesotaDaveYou should have said you welded it that way with an Everlast and it was "good enough" because you tested it with a ball pean hammer
Reply:You go to the 1st strike auction in the squarebanks?.  Lots of equipment at that sale.
Reply:That's perfect!I'd use that truck to haul Bob's food trailer bastardization that he has to repair down a lonely country road.....Then when it fell off I'd laugh into the sunset and go collect the insurance Lincoln SA 200Esab Caddy 160Thermal Arc 201TSMiller Dialarc HFI don't like making plans for the day because then the word "premeditated" gets thrown around the courtroom....
Reply:Originally Posted by akpolarisYou go to the 1st strike auction in the squarebanks?.  Lots of equipment at that sale.
Reply:It'll be fine!Its welded on both sides!Think of it this way, when you are pulling on it, it will bend back up to where it belongs (pulling).It may sag a little when you stop as the tongue weight will come back!
Reply:Originally Posted by drujininIt'll be fine!Its welded on both sides!Think of it this way, when you are pulling on it, it will bend back up to where it belongs (pulling).It may sag a little when you stop as the tongue weight will come back!
Reply:That's a 16' bed on that truck....Truck sold for $4000
GMT+8, 2026-1-1 03:50 , Processed in 0.095828 second(s), 18 queries .
