Aluminum welding table?
发表于 2021-8-31 22:27:36 | 显示全部楼层 |阅读模式
Today dad called me into his office, said he had a build in mind for me (theres a long list now) he said he wanted some good ramps built for pulling trailers in and out of semis. We have this odd piece of 3/4in aluminum that we've been using but its not wide enough and trailers slide off the sides if they dont track right or not centered right. I asked dad what he was going to do with the old ramp and he said he was going to sell it for scrap unless I could use it. I was thinking of cutting the short side off and making a welding table that either bolts to a steel frame or build an aluminum frame. I wanted you guys opinion on it if it worth it or not. Cause my 3x6 expanded metal table is on its last leg.
Reply:I am sure a lot would say no but if it is not worth scrap price to use as a table I don't know what is. I would just use it as a quick table as is in the bed of the truck or tossed up on saw horse.
Reply:You wouldn't have to worry about spatter.
Reply:It will be a heck of a lot better than the chip boards I throw on saw horses when I run out of table space Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Would be sweet.
Reply:What do Yall recommend for the frame?
Reply:MORE SCRAP SON, that is what mine is made of.RegardsDave
Reply:Originally Posted by smilindaveMORE SCRAP SON, that is what mine is made of.RegardsDave
Reply:I like that idea.  It would stiffen the top and not have bolts directly into the top.
Reply:Originally Posted by Going nowhereI like that idea.  It would stiffen the top and not have bolts directly into the top.
Reply:Originally Posted by swampwelder13That's kinda where im at. Im thinking some 2in 1/4in aluminum angle welded to the bottom in a square then having a steel frame that bolts the aluminum angle to the frame with some 1/2bolts. Preferably 2 on each side. 8 total
GMT+8, 2026-1-1 00:21 , Processed in 0.106724 second(s), 18 queries .
