Root spade
发表于 2021-8-31 22:27:36 | 显示全部楼层 |阅读模式
This is a attachment I made to dig mulberry and wild cherry sprouts out of my other bushes.  Cutting them off at the ground only makes them come back stronger. You push the spade in to the ground under the tree to be removed, lower the forks and it pops out of the ground. Constructed out of 3/8" steel with 3/4" bolts to hold it on.   Yes, I did drill holes in my forks with my mag drill. I considered hard facing the cutting edge but it's holding well so far. Dan Attached ImagesManipulator Of Metal
Reply:That's bad *** right there.
Reply:Clever and simple. Good job.
Reply:Awesome. My Kubota is gonna get one of those. You can paint yours green and I'll paint mine orange.Did you notch out the center for some additional fork stops?Based on the size of the tractor in your picture, I have hopes of it working on mine. I took the bucket off and repair/weld/retrofitted a fork attachment for a skid steer to fit my loader. That was my first major project with fabrication and welding and you have shown the way for me to like it even more.Thanks.
Reply:Originally Posted by chuckholeAwesome. My Kubota is gonna get one of those. You can paint yours green and I'll paint mine orange.Did you notch out the center for some additional fork stops?Based on the size of the tractor in your picture, I have hopes of it working on mine. I took the bucket off and repair/weld/retrofitted a fork attachment for a skid steer to fit my loader. That was my first major project with fabrication and welding and you have shown the way for me to like it even more.Thanks.
Reply:Please send a close up pic from the side of the spade.  Neat idea!  Tkanks.Jerry30+ yrs Army Infantry & Field Artillery, 25 yrs agoMiller 350LX Tig Runner TA 210, spool gunLincoln 250/250 IdealArcESAB PCM 500i PlasmaKazoo 30"  vert BSKazoo 9x16 horiz BSClausing 12x24 lathe20T Air Press
Reply:I sandwiched the forks between the plates and left a little slop.  It fits almost too tight.  When I welded in the angle the bottom curled up pretty bad. I suggest leaving the cutting edge about 4" long, weld it up, straighten the edge then finish the cutting edge. Dan Attached ImagesLast edited by DanD78; 07-01-2014 at 06:44 PM.Manipulator Of Metal
Reply:That's a nice spade.  I like that idea.  One of those would be nice for our Kubota.  Good post
Reply:Smart thinking! Very well thought out; glad this works well. I might copy this idea. Well done.Old tools, trajan band saw, grizzly, delta,lincoln
Reply:Nice!  Ever seen the big muthas for big trees?
GMT+8, 2026-1-1 00:20 , Processed in 0.098829 second(s), 18 queries .
