Different Style Welding Table???
发表于 2021-8-31 22:27:35 | 显示全部楼层 |阅读模式
Looking at the thread on the bed frame.....I noticed the welding table in the background. I need a bigger table but am pressed for room. I was thinking about building a portable top out of 2 x 2 x 1/8 tube .......no solid top. This would give me something portable and also would give me more clamping options. Provided I can build it flat  will this work?
Reply:I think it will. I once knew a welder that made security storm doors. His table was square tubing in about 12-24" squares. He could clamp anything on that table. Good luck.Hobart 125 EZHobart Handler 140Everlast STH 160Generic 210 Amp Welder/GeneratorHobart Air Force 500i plasma cutterChinese 50 amp plasma cutter! Youtube Channel : Henrymac100
Reply:SqWave 200Millermatic 190Airco 200 ACHypertherm PM45Boice-Crane Band SawVictor O/A
GMT+8, 2026-1-1 00:21 , Processed in 0.099057 second(s), 18 queries .
