Welding on generator
发表于 2021-8-31 22:27:31 | 显示全部楼层 |阅读模式
Okay I haven't asked a dumb question in a while. My math if correct tells me my 3k running 3.7 load will produce 22 amps? My 120v welder should run okay on this right?Sent from my iPad using Tapatalk
Reply:Ptobably not due to inrush surge.  Probably need 1.5 to 2.0 times generator output to handle this.  Others may know better.Dan D.Manipulator Of Metal
Reply:Holly crap I don't even know what that means. Sent from my iPad using Tapatalk
Reply:Originally Posted by Bluehunter40Holly crap I don't even know what that means. Sent from my iPad using Tapatalk
Reply:If you have a Lincoln 135 the max it should draw is about 20 amps, depending on the electrode and how you run it.As long as you are not trying to run .035 flux core for all the machine is worth then it should do fine on a 3kw generator.old Miller spectrum 625 Lincoln SP-135 T, CO2+0.025 wireMiller model 250 and WP-18V torchCraftsman 100amp AC/DC and WP-17V torchCentury 115-004 HF arc stabilizerHome made 4 transformer spot welderHome made alternator welder
Reply:Originally Posted by DanD78Ptobably not due to inrush surge.  Probably need 1.5 to 2.0 times generator output to handle this.  Others may know better.Dan D.
Reply:Probably work alright, just have the generator up to full speed and welder NOT maxed out when you first try it. Then bump up the welder output a little at a time to see how high you can push it and still weld OK. Probably the worst that will happen is, you will trip the breaker if pushed too hard.
Reply:run .030 wire if your fluxcore, you should be fine.face all times with a positive mental attitude,then and only then will you have done your best.
Reply:Okay I'll try the .030 fluxSent from my iPad using Tapatalk
Reply:Originally Posted by Bluehunter40Okay I'll try the .030 fluxSent from my iPad using Tapatalk
Reply:I don't have a 135, I have a Lincoln 180 duel. I did have a few 110 Lincolnshire, I was thinking I might pick up another. My plan was to use the 180 with the 110 plug. I welded with the 180 in 110 mode last week with my 5kw generator and it did just fine. This generator does have 3700 surge watts so I was thinking it would work.  Sent from my iPad using Tapatalk
Reply:Originally Posted by Bluehunter40I don't have a 135, I have a Lincoln 180 duel. I did have a few 110 Lincolnshire, I was thinking I might pick up another. My plan was to use the 180 with the 110 plug. I welded with the 180 in 110 mode last week with my 5kw generator and it did just fine. This generator does have 3700 surge watts so I was thinking it would work.  Sent from my iPad using Tapatalk
Reply:Surge on a welding machine sucks power a lot more than any normal device.old Miller spectrum 625 Lincoln SP-135 T, CO2+0.025 wireMiller model 250 and WP-18V torchCraftsman 100amp AC/DC and WP-17V torchCentury 115-004 HF arc stabilizerHome made 4 transformer spot welderHome made alternator welder
Reply:i have a miller 180, about ten years old, i run a 220 line on it, ,.030 outperforms the .035 bigtime, using .035, i reach the maximum duty cycle very quickly and trip the internal thermal  protection switch, using .030, i'm smooth as silk and can push the machine for quite a while.....030 naturally draws less amperage than .035 and brings the main power supply requirements down somewhat, enough to get'r done anyhow!.face all times with a positive mental attitude,then and only then will you have done your best.
GMT+8, 2026-1-1 01:56 , Processed in 0.096220 second(s), 18 queries .
