Johnson Model J band saw
发表于 2021-8-31 22:27:30 | 显示全部楼层 |阅读模式
I bought this unit when I moved into my shop. From what I know its a johnson vertical band saw model J that is 10x18. I have used the saw a handful of times and it has always gave a good cut. It runs off of 115 volt and the coolant pump dose work but I have only run water in to  make sure it was working when I bought it. since then It has been used dry for smaller material Asking $750.00 o.b.oAdam MMorales Ranch
Reply:you might want to resize your photos so we can see everything your typing and your location.. good luck with sale
Reply:looks like a horizontal bandsaw to meDynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:Hey, I just sent a guy in Sugarland an email about a horizontal bandsaw.   : )What are the overall dimensions and weight of this beast?  I was really looking for smaller horizontal bandsaw.
GMT+8, 2026-1-1 00:21 , Processed in 0.073131 second(s), 18 queries .
