97 dodge diesel
发表于 2021-8-31 22:27:27 | 显示全部楼层 |阅读模式
thinking of selling my 97 dodge diesel 2500 reg. cab 4x4,flatbed. i think i would rather buy a dually 4x4 or even trade for one.minehas new auto trans 500 miles ago 198,xxx miles runs great no problems at all let me know if you might be interested. Attached ImagesLast edited by kswelderman; 10-18-2010 at 03:14 PM.Reason: picsMM 251MM 135Lincoln Pro cut 55Bobcat 250Miller Thunderbolt ac/dcolder ac forneyJackson nexgen 3n13-Smith OP setups97 Dodge dieselMakita chopsawJet swivel head bandsawlincoln tig 300/30030a spoolgunpuma port. gas air comp.
Reply:You could always swap on a dually rear end and spring packs if you like the truck.If you don't want mismatched wheels, you can either run adapters on the front hubs or get the relevant parts from a donor.http://www.dieseltruckresource.com/d...n-t226162.html
Reply:Farmall is right Dually Conversions are pretty easy, If you check out www.cumminsforum.com i bet you will be able to find someone that will trade you a dually banjo for your single wheel axle. One thing you need to check on is GVW, you will still have the GVW requirements associated with the 2500s vin number. My 95 reg cab long bed 2500 Cummins has an 8800gvw (yours is the same) and tips the scales at 6700lbs empty with 30 gallons of fuel in the tank, so watch your weight if you are going to throw a welder and leads and etc... on the bed. A 3500 vin on the other hand would be tied to an 11,000lb GVW. I dont know how picky the DOT is where you live but they love breaking guys balls by me.Miller Dynasty 300 DXMiller CST280Miller Maxstar 150 STH
Reply:I only say this because that truck looks like it is pretty solid, has a new tranny and not too too many miles, one last thought is just some wider tires, i have 12.50w tires on my truck with an extra leaf and air bags and she tows a 10,500lb trailer with no problems. Here it is with my father's Kubota loaded.Miller Dynasty 300 DXMiller CST280Miller Maxstar 150 STH
Reply:If you DON'T overload it as far as DOT knows, keeping the lower legal weight often has tax advantages...
Reply:the dodge is still for sale 6500.00MM 251MM 135Lincoln Pro cut 55Bobcat 250Miller Thunderbolt ac/dcolder ac forneyJackson nexgen 3n13-Smith OP setups97 Dodge dieselMakita chopsawJet swivel head bandsawlincoln tig 300/30030a spoolgunpuma port. gas air comp.
Reply:any offers at all ? ive found a dually i want but i need to get this one sold first.will trtade for a dually 94-97 man. trans or sell mine outrite with flatbed or c&c.MM 251MM 135Lincoln Pro cut 55Bobcat 250Miller Thunderbolt ac/dcolder ac forneyJackson nexgen 3n13-Smith OP setups97 Dodge dieselMakita chopsawJet swivel head bandsawlincoln tig 300/30030a spoolgunpuma port. gas air comp.
GMT+8, 2026-1-1 01:56 , Processed in 0.096740 second(s), 18 queries .
