CWB all position stainless
发表于 2021-8-31 22:27:25 | 显示全部楼层 |阅读模式
Has anyone out there done the CWB all position stainless ticket (stick)?I am wondering what the set up is and what type of rod is used, as well as rod size.Any info would be great.Thanks.
Reply:I'll see if I can find someone who knows next time I'm on the job.  Hard to find info about CWB tests online, isn't it?       Which local are you in?
Reply:Local 1425 Sudbury Ont.
Reply:Awesome, 2309 here!
Reply:O.K. hope you have lots of work coming up in TO. Any info you can find would be great!for now I am going to try to practice with 308 with a 1/8 rod and assume the same set up as the mild steel test.
Reply:I would think it would be with 1\8" 309L-15or16 I have rarely use any 308 because on repairs I never know what grade I am welding  but they both weld the same to me
Reply:Why not call the CWB for more info. Or inquire at a test centre near you.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
GMT+8, 2026-1-1 00:20 , Processed in 0.102624 second(s), 18 queries .
